Hey all,
I've been using the air conditioning recently, for the first time since I bought this car last Dec. It works (gets nice and cold), but makes some noises and things and I just wanted to get an idea of what is normal on these cars. (My last 850 that I had for 5 years never had working AC).
It seems to click on and off every 10 sec. or so - you can hear an audible click if the car isn't moving fast. Also, it makes noise, a sort of fan like sound that is definitely not just the fan, since I only hear it when the AC is on. It's like a low pitched whirring.
The other thing is that when it cycles on and off when I'm going at highway speed it feels like it's taking a lot of power from the engine. It feels as is I had pulled my foot abruptly off the gas pedal - I'm assuming this is when it clicks on.
Are these types of things normal on 850 AC systems?
Thanks!
1997 850 AC weirdness...
thedancingfiddle
- Year and Model: 1997 NA 850 wagon
- Has thanked: 1502 times
- Been thanked: 3813 times
If your system is overcharged the compressor will be working hard, whir, and you will feel it take load from the engine . You will get the same if the compressor is worn or corroded inside
Any history of adding Freon or a long time with no Freon?
thedancingfiddle
I got this car from the original owner, and have all the service receipts. I can't find anything about the AC system anywhere, so my guess is that it hasn't been serviced in a long time, or never. There are a lot of service receipts here, so I may have missed one, but most are in order and I looked as far back as 2004.
Should I get it checked out and/or Freon added? I don't want to kill the compressor!
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
Mine was cycling on and off last year, as yours is,every 10-20 seconds, a little noise , but not noticeable power loss from the motor. I purchased a can with a gauge on it and added an amount for the temp of the day. In all respect, I think the amount added was to much and will fix the situation soon.
I was looking at the bread clip fix, but adding the Freon seemed to fix the cycling on and off.
Good luck and post if you fix the problem. Seems these systems are running out of time as they get older.
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
thedancingfiddle
Thanks for the tips. I'm getting it looked at next week, along with some other small things, and I'll let you know when I know more!
thedancingfiddle
Got the AC recharged, which fixed the cycling on and off. My mechanic didn't find anything else wrong with it, so hopefully that will do it.
I haven't yet had a chance to drive it on the highway to check for power loss, but I might not notice it now without it clicking on and off constantly. It still does make some whirring noise when the AC is on, but if the compressor is worn, it's just a matter of time before it dies, right?
- Year and Model: Many Volvos
- Been thanked: 75 times
The whirring noise is perfectly normal.
It is a matter of time, measured in decades, if you have stored sufficient karmic points. The good news is it will give you good warning of impending death.thedancingfiddle wrote:Got the AC recharged, which fixed the cycling on and off. My mechanic didn't find anything else wrong with it, so hopefully that will do it.
- 922 Views
Last post by IG-88A
- 687 Views
Last post by jibbersmcgee
