1990 780 turbo horrible/no start
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
2slow4u
Year and Model: 1990 780 turbo
Post by 2slow4u »
Good afternoon fellow peeps. 780 bertone turbo been in storage for 2 years with no regular starts, today decided to jump on it and get it going again. Went through all typical checks , found fuel pump inline not working so replaced. Vehicle doesn't want to fire up after establishing that I have fuel in rail and injectors, and spark....... nd suggestions, thanx :wink:
difflock54
Year and Model: V40 Nordic 2002
Has thanked: 7 times
Been thanked: 2 times
Post by difflock54 »
Using fresh fuel or the old stale?
Try a few squirts of ether to help her.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
2slow4u wrote:after establishing that I have fuel in rail and injectors, and spark
How did you determine:
1. Spark
2. Injectors Firing
Are spark plugs wet/dry?
Has thanked: 1505 times
Been thanked: 3818 times
Compression test is in order. Letting a car sit for 2 years without a start is essentially the same as putting sand into the motor, so problems are to be expected. If moisture has permeated the cylinders and damaged them, a new engine might be the order of the day.
