This is my first post in this forum.
I have a 2000 V70 and the a/c is giving me problems. About a week ago I noticed that when I had the fan on high (not on auto), that the fan would speed up when I braked. Then about 2 days ago, the fan completely stopped blowing. My brother removed the fan motor and tested it and it is working. He reconnected it. One time he turned on the car and the fan turned on and ran. The next time, nothing. We're wondering if one of the sensors or relays are out? Any way to tell that without taking it to the dealer? Is there a way to re-calibrate the ecc? Any help is appreciated. Thanks!
2000 V70 a/c fan speeds up when braking
jimmy57
- Been thanked: 320 times
The bushing in one end of fan motor that controls the end float (axial control of motor shaft) wears and it binds and makes brush contact worse. Those things will slow motor down but when you brake and the armature moves forward it releases the bind and speeds up. When you had the blower out could you grab fan wheel and pull it up and down?
- Has thanked: 1507 times
- Been thanked: 3824 times
Mine sped up and down with movement of the connector. The new replacement from IPD wasn't cheap but we had a harsh winter and I got my money's worth out of it!!
Thread on replacement posted in March I think
- Has thanked: 1853 times
- Been thanked: 1714 times
Really glad you posted this problem! Was driving my son's car today and had the exact same problem. When I braked the fan sped up, and when I accelerated it almost stopped. Typical, the car is to be sold and this happens. Fan on order.
- 714 Views
- 3777 Views
Last post by englemancr
