'98 V70 camshaft seals and crank seal
Hey all doing a timingbelt/water pump on my V70. 140,000 on it. So in my kit it came with cam seals for the timing belt side and a crank seal . Is this a necessary change? Is there typical failure like the seals on the other side of the camshafts. The cam seals look easy but the crank seal at the oil pump does not look fun. Any thoughts would be appreciated. Thanks
paul
'98 V70 awd
'83 BMW R80RT
'98 V70 awd
'83 BMW R80RT
- Been thanked: 471 times
If the cam/crank seals do not leak, leave them alone.
The CAM seals are NOT easy, especially the exhaust seal
The CRANK seal is part of the Oil Pump kit.
Otherwise info below:
https://www.matthewsvolvosite.com/forums ... hp?t=53722
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
I would say if it is not broken, then leave it alone. If your PCV system is working good, and pressure is not building up, (balloon test on oil dip stick), leave it be. At 140,000, that is young.
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Also, many of the kits you buy on the web contain second-rate seals, they are notorious for leaking.
So if you replace the factory Although old) seals with the seals that came with the kit, you can almost be sure that they will leak in the near future.
Anyway, leave the seals alone.
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
Agree leave it alone ..... I have all new wires, plugs, condenser, rotor, and Volvo plugs, just waiting to tune her up, shes running just fine. I have a crack front seal leak, and I'd like to change the oil pump seal while I'm at it,, shes a sweetheart of a car, and I'll wait to tune her after the oil leak is fixed.
