1996 T5 Auto Fault code 444 after installing new T5R ECU
I have a 850 T5 Wagon 1996 which had a faulty ECU unit so I thought I would up grade to the T5R unit coded 0 261 203 628 (USA Auto T5R Version). After installing the error code 444 came up and cannot be reset. Does the T5R have an acceleration sensor which is either not on or different from the original T5 version 0 261 203 852.
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
You should always replace with the exact same ECU. Same year and numbers.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
- Has thanked: 312 times
- Been thanked: 818 times
Are you getting the code from the OBDii port, or is there a diagnostics box under the hood (there would only be ODBii on a US model 96)?
If the code is from the OBD reader then it is a simple evap code, possibly the purge valve is leaking.
It's totally fine to put a 628 ECU into a regular T5, even to switch model years (my 95 has run on a 96 ECU for years now), but you do need to watch for which of the various emissions gadgets were included in the two vehicles involved. Especially air pump and EGR, depending on the years, were installed or excluded seemingly randomly in many cases.
- Has thanked: 2864 times
- Been thanked: 1332 times
This. I've had a "628" ECU in my 1997 850 T5 for two years.erikv11 wrote:It's totally fine to put a 628 ECU into a regular T5, even to switch model years (my 95 has run on a 96 ECU for years now), but you do need to watch for which of the various emissions gadgets were included in the two vehicles involved.
- 2553 Views
Last post by TripleThreat719
- 3213 Views
Last post by misha
- 3210 Views
Last post by RickHaleParker
- 3341 Views
Last post by foggydogg
- 18 Replies
- 20253 Views
Last post by doublebug
