Check engine light is on, know the problem, need extra help
M81388
Post by M81388 »
Hi, i own a 1994 Volvo 850 Non-Turbo 2.4L 20 Valve. My "Check Engine" Light came on about a week ago. I searched the forums and found out how to check for diagnostic codes, so I did a check on 'A2 - Fuel System' and the code '1-3-2' came up, then I did a little more searching and i found out that it means that the Battery Voltage is too low/high. How do I narrow it down from there and over all fix the problem?
Thanks Alot.
Tsquared
Year and Model: 11 C30
Has thanked: 1 time
Post by Tsquared »
My first thought would be a voltage regulator. Have you had any problems recently with the battery or starting the car? Does your battery show any signs of overcharging (moisture around the vents or swolen battery)?
T2
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I would suspect a dying battery (too high or too LOW, right?).
M81388
Post by M81388 »
The thing is, i recently bought a new battery (bout 6 mos. ago). However, I've noticed that every single time i get out of the car and shut the door, my hand gets zapped by the car. Very annoying. I want to avoid taking it to a mechanic though. BTW, sorry for the delay of my reply, but my Internet has been down.
White850Turbo
Post by White850Turbo »
That code is certainly not one that I see people have very often. Best bet is to reset it, see if it comes back, and if it does, replace the voltage regulator.
-Sean
1998 S70 T5 (Almost Stock)
Jot
Year and Model: C30 2010
Post by Jot »
The "zap" is static electricity which is common in the winter . I doubt it has anything to do with the battery
