tailgate glass replacement
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
2forty
Year and Model: 850 1996
Been thanked: 2 times
Post by 2forty »
Are there any videos on how to replace the tailgate glass? I have a 87 240 wagon.
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
2forty wrote:replace the tailgate glass?
What for? Indestructible volvo glass
Ask around...votech school, body shop.
I don't know if front is same as rear window, but: Replacing Windshield Glass
2forty
Post by 2forty »
I found the tailgate glass for my 87 240 at a repair shop. 100 bucks. The owner informed me how to install it. So simple. The glass in held in place by the gasket only. So from the inside remove the panel on the tailgate and disconnect wires attached stoplight and glass. Just look at the wires it is easy. Then using a scraper and flat screwdriver from the inside with someone holding the glass on the outside begin prying the rubber molding off of the tailgate. Just take your time and work it off...To install I lubricated the rubber molding with syl glyde to make it slide in place easier. With a helper holding the glass in place on the outside, work the rubber molding back on the tailgate using a couple of flat tools. I used a scraper and screwdriver. EASY! Once in place connect your wires, reinstall the panel and your done.
