99 V70 Ignition Switch Stuck
JeffHicks
Year and Model: 1989 240 Wagon,
Post by JeffHicks »
This is weird. Out of the blue, the key will not "unlock" the ignition switch and allow me to start the car. No warning of any kind - in fact, I was driving the car earlier today. It hasn't been sticky, hard to turn, anything. But all of the sudden it acts like I have the wrong key in it.
Any guesses?
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Try to start it in neutral.
JeffHicks
Post by JeffHicks »
rspi wrote:Try to start it in neutral.
I cannot do that. The key will not turn in the ignition.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
Start with a shot of WD40 into the key slot.
Run the key in and out a few times to loosen
things up and try again.
Is this an auto or manual transmission car?
JeffHicks
Post by JeffHicks »
Got the job done guys. Got "creative" with the cylinder & barrel.
I did the entire removal - including steering wheel - which turned out to be far less troublesome than I anticipated. Everything is re-assembled, and we're back in business.
The one thing I'm a bit puzzled by is that my "SRS" light on the dashboard stays on now. I know I got the air-bag connector reattached properly, and everything else is operating as before. But that light is on.
Any guesses?
BEJinFbk
Post by BEJinFbk »
My guess is that you isn't disconnect the
battery before disconnecting the airbag.
You'll need a dealer level programming
unit to reset the SRS diagnostics.
And your bags won't fire until then.
JeffHicks
Post by JeffHicks »
BEJinFbk wrote:My guess is that you isn't disconnect the
The battery was disconnected. Learned to do that the hard way, about 25 years ago.
