1997 960 low beams won't turn on
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Re: 1997 960 low beams won't turn on
Post by 93Regina »
GH960 wrote: Any help.
trace it out
I'm away from home...
93Regina
Post by 93Regina »
GH960 wrote:97' 960 won't light up
Volvo Owner's Manuals
They say in the Owner's Manual: If an electrical component fails to function, it is likely that a fuse has blown due to an overloaded circuit.
So, here's the info on fuses:
pg. 6:13 Fuses
93Regina
Post by 93Regina »
GH960 wrote:I checked continuity on all fuses
All newer vehicles tend to use relays...diagram (pg 20) shows there is a relay for main headlight is behind dash and left of steering column.
On page 26, it shows actual circuit...and it appears to be a high dollar relay. I would check to see if light switch is sending voltage to relay...to right of light switch is high/low beam switch...with a voltmeter, one might be able to determine if signal voltage is getting to relay on both circuits.
Hence, your relay or high/low switch could be shooting craps.
93Regina
Post by 93Regina »
GH960 wrote:but it looks like my headlight switch is bad
Good to hear...The Parting Glass
