03 s60 vacum assist pump/brakes
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
mikel
Year and Model: 1966-2000-2003-2007
Post by mikel »
My 2003 s60 NA is starting to whistle when you let off of the brake pedal. The Vacum pump runs after you turn it off for a few pulses.
The brakes work fine and no CEL. I assume it will get worse. Do I need both or just the vacum pump?
no chance it can be an adjustment?
...michael
cmbfoto
Year and Model: 99 S80 02 XC70
Has thanked: 11 times
Post by cmbfoto »
What did you find out with the vacum problem?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
didn't see this one 3 years back. The booster is why it would hiss. The leaking is why the pump runs. No need for pump unless it dies from too much running when booster leaks. Booster has equal vacuum front and back of diaphragm(s) when pedal released. When you depress pedal the first thing that happens is the backside vac is shut off and then further push bleeds out vacuum which lets pressure build towards or to atmospheric for the level of assist that matches your level of pedal apply force. If the regulator valve on back of booster (pedal pushrod goes to this) fails then it leaks vacuum. If the leak is bad it will self apply brakes with no foot on pedal. Usually just enough to drag brakes and make them smoking hot in a few miles
