Remove dents
Pretribrapper
Year and Model: 2011 C30 2.0 T5
Has thanked: 51 times
Been thanked: 6 times
Remove dents
Post by Pretribrapper »
I brilliantly drove into my garage with my mountain bike up top... now I have four dents and a little messed up paint. Want to get dents out but dont know what is best DIY. I have heard suction cup kits, slide hammers with glue tips, all sorts. Any good suggestions
Masscomguru
Year and Model: 2010 XC90 V8
Been thanked: 16 times
Post by Masscomguru »
try using a blowdryer or heat gun to heat it up and then rub over it with ice cubes. or a can of compressed air (upside down) to freeze it.
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Post by cn90 »
Park the car outside the entire summer.
The heat from the sun will bake the sheet metal and most of these will pop back out.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Volvos are tough metal. My body man says they are the worst to work on because they are the best for safety. That said I think the solution would be paintless dent repair. Dropping the headliner should give access to the dented areas and a good PDR person can make those look pretty much like new.
Because the metal is premium quality - little tricks that work on lesser cars most likely will not work. I suppose you can try, but I have a dent on my XC90 hood and it has not changed at all. It needs to be worked out physically - for me it is not worth it - but my body man says his PDR man can do it for $150 no problem.
