2005 XC 90 4.4 V8 non turbo auto Topic is solved
nisan17
- Year and Model: 92 940 turbo
- Has thanked: 2 times
Question(s) regarding 2005 XC90 V8 4.4 Yamaha with auto trans and no turbo. My daughter is looking at buying this model with 82k on the odo. What should she be concerned about? It has nothing wrong that we've been told or could see. Doesn't use oil, fluids, hoses and belts are good. Oh the oil level light goes on every now and then, but a supposed mechanic says bad sensor and shouldn't be alarmed. Thanks for any input.
Kevin
Masscomguru
- Year and Model: 2010 XC90 V8
- Been thanked: 16 times
That particular model year has a particularly nasty issue with the center balancing shaft. The bearings let go. It’s reparable if you catch it, but if not it will destroy the engine. It’s also a complete tear down to replace. The mileage varies on failure greatly. Some never do some less than 100k some later in life. Aside from that they all need valve cover replacements at some point.
That being said, the oil thing is ok. They light up with only 1/2qt low and on a 7500 mile OCI that’s not too bad.
If you are looking for these in that year range I would recommend the 2.5 over the T6 or V8.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The balance shaft bearing issue is a big deal and worth an inspection by someone familiar with Volvo V8s. The problem has a remedy by removing upper intake and drilling the drain hole that 2006 and later have with a long drill bit. It is not a big job but the drilling only goes 1/4 inch to go into an area where any water can drain. Water is not usually going to be there but if the engine gets washed it is a risk.
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
I have the same XC90 - I agree with the other posters - the issue with the balance shaft bearing is due to washing the engine, or in my case, I think I got some fuel in there when I changed the fuel pressure sender. To fix it, you have to remove the intake manifold and one of the cylinder heads. That said, it still runs nicely, and that's the only major issue with the engine. It's got a timing chain, so no belt to replace. From numerous discussions, fuel economy seems to be about the same no matter which engine you have, so it's really a function of it being a big, heavy vehicle. I get 17mpg pretty consistently. (The people in England with the diesel engines always post ridiculous mpg, but it's diesel, and they're measuring in imperial gallons...)
Also, I find my oil level sensor is fussy about what kind of oil I put in. Specifically it does not like Castrol Magnatec, and will give me erroneous low oil readings all the time. It took me changing out a $100 sensor and no change to figure that one out.
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- 1725 Views
Last post by mf70
- 1166 Views
Last post by E Showell
- 2397 Views
Last post by bmdubya1198
- 1493 Views
Last post by Guduza
- 167 Views
Last post by rrres
