1998 v70r ABS - TRACS OFF illuminated
mrjacobrussell
- Year and Model: 2006 s60R
- Has thanked: 2 times
Both lights are on and the speedo intermitently goes out. when the speedo is working the cruise works. when the speedo is dead the cruise and trip meeter stop workin. I have read about having to take the modual out and resolder the contacts. Is there a way to test for continuity accross the connector pins ?
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
2005 v50 t5 AWD for sale
I have a Chinese DICE, works well.
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
Yes, but it's pointless as a good amount of them will be cracked regardless. Also the cracked pins shift when removing or reinstalling the harness so you would never get a true reading.
If you've gotten to the point where the speedo is dropping out that module has been on a downhill slide for a long time.
You can test wheel sensor circuit continuity through the harness.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
It's been said here a million times -
There are two kinds of ABS modules:
The ones that have failed
and the ones that will fail...
Pull the box and fix it or send it off to Matty Moo.
He's been doing it for a while now. Great rep, rates
and an unbeatable module exchange program:
https://midwest-abs.com
mrjacobrussell
one more question and is it also possible that the ABS module is affecting the power assisted steering rack?
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
Matty Moo
No.
2000 s70 GLT
2014 Ram
mrjacobrussell
I pulled it and soldered it. This fixed the Speedo dropping but the random abs pumping in and out continued. I found the wedge fix and used a piece of card board folded in half. The abs has been out fir over 2 weeks..
This begs the question.. is it the connector on the ABS or the harness connector? I was thinking about pulling the harness Back and inspecting the connectors inside the harness
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
Matty Moo
If you have to jam something in there to make it work then you didn't solder all of the pins correctly. At that point the harness isn't part of the equation. The biggest thing on a 96-98 module is prep before repairing it, every last bit of that rubber membrane has to be off of all the pins.
2000 s70 GLT
2014 Ram
- 22 Replies
- 4585 Views
Last post by hausmeister
- 2065 Views
Last post by rguzz
