1998 V70 XC Engine Removal -Top or Bottom, With Trans or WO
superfeed
Year and Model: 1998 V70 XC
Post by superfeed »
I am going to swap in a much lower mileage engine into my V70 XC. Wow, a lot of stuff in this little compartment!
So....
Out the top or bottom?
With transmission attached or without?
Any advice.... PLEASE!!!
Thanks!!!!
John
tryingbe
Year and Model: None
Has thanked: 1 time
Been thanked: 26 times
Post by tryingbe »
I prefer remove from bottom, with the turbo, sub frame and trans still attach to the engine.
85 GLH, 367 whp
00 Insight, 72 mpg
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
I don't have experience with the AWDs and you may want to hear some posts from someone who clearly states they do, it is pretty different from a FWD. I like to take those out the top, everything still attached, it is pretty darn easy that way when you are working in a home garage. But that's not AWD ... wish I knew more!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
It largely depends on what you have available to you. With a lift the bottom is the way to go but I did just fine coming out the top, with the transmission but not the transfer case, using an engine hoist.
If you try to pull just the engine you need to drop the subframe halfway off to get the transmission disconnected so it is actually considerably more work than just taking them out together.
superfeed
Post by superfeed »
Thanks for the input everyone!
superfeed
Post by superfeed »
Much Love, Good Volvo People,
Can I put the wheels on and move the car around if I take the front axle shafts out?
tryingbe
Has thanked: 1 time
Post by tryingbe »
You can, but not recommend. The bearings can come apart with nothing bolted it down.
85 GLH, 367 whp
00 Insight, 72 mpg
Post by erikv11 »
I've rolled it back and forth a few feet a couple times, but always afraid to do more than that. It helps a lot that there is so little weight on the front of the car with everything removed. You can get car dollies at Harbor Freight etc., set the front wheels on them, they have different styles for different prices e.g. http://www.harborfreight.com/2-piece-ve ... 67511.html
'06 S60 R, 197k
superfeed
Post by superfeed »
Those are cool. Might just do the trick. to get the front wheel shafts out, I'm looking at the calipers, axle nut, rotor, and lower ball joint? This 36mm axle nut is on very tight. I have sprayed penetrant on it but I'm a little afraid to brake my big 1/2" ratchet. I've put my full weight on it but still holding fast...
superfeed
Post by superfeed »
break my.....
