1997 850 wagon front left blinker
Tobers
Year and Model: 850 wagon, 1997
Post by Tobers »
I'm stilling trying to figure out what's wrong with the left front corner light. i have the right bulb: 1157A. I've put two new ones in there. I've replaced the hazard switch with another one (used), so unless both are bad, that's not it. Here's what works and doesn't:
1. the bulb works for the flashers. the bulb works for the turn signal
2. the corner light does NOT come on for the headlights, nor for the parking light position.
is it my headlight switch? (in a previous post this was suggested) Anything else might cause this? The wires look good. thanks. Rick
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
It could be the socket. I would take a volt meter and start at the light socket and work my way back. If the switch was bad neither of the corner lights would work.
kahl
Year and Model: 2000V70XC
Been thanked: 10 times
Post by kahl »
Do your license plate lights work?
Tobers
Post by Tobers »
it's not the socket. i disconnected the socket and plugged my 12volt tester into the wire plug that attaches to the socket. i am not getting voltage up the wire.
***My license plate lights do NOT work.
is this a key? thanks. rick
kahl
Post by kahl »
the front left marker light and the license plate light share the same fuse. You need to inspect the wires in the tailgate left hinge area. I think you will find broken wires.
Post by Ozark Lee »
That is a great picture of a common problem. It comes from slamming the trunk on a hard object that is under the hinge and it is often hidden inside of the mesh wire loom where it isn't obvious.
Tobers
Post by Tobers »
I took off the plastic protector and a small section of the wrap. the wires look perfect. is there a way to unwrap the whole thing, or look more closely? Or find the wire that is the culprit? At first look the wires don't appear to be the problem, but it seems like it might be. I'll search the site. thank you.
kahl
Post by kahl »
keep going up the wrap into the car.
Has thanked: 1497 times
Been thanked: 3810 times
You have to cut the snake skin a bit at a time and probably remove the rear trim pieces (easy) to find the break. Mine broke where the cable was zip tied to the frame as that point became the flex point. Bad design.
Great thread on fixing it here
https://www.matthewsvolvosite.com/forums ... 70#p332020
Tobers
Post by Tobers »
It might be solved; we'll see. MANY thanks for all of the help. I searched the wires in the tailgate harness over and over; they look great. Then I realized I put a couple of screws in the tailgate to cut down the rattles ... maybe I hit something. I checked those and didn't find anything. Finally in frustration, I went back to where I started: the fuse box. The fuse was blown. So either I missed it when I checked at the beginning, or somehow blew it while playing with all of the wires. I replaced it and will cautiously watch what happens. It all works for the moment.
