2007 2.5t v 70. Motor mount failure upper
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Driven
Year and Model: V70 2.5t 2007
Post by Driven »
How do I tell if motor mount is needing replacement?
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
Rubber is cracked. Or ask you buddy to push pedal gently and see if the mount can hold the engine without showing any gaps or even touching metal.
Driven
Post by Driven »
Thanks I will give that a try, rubber is not cracked but it does seem loose when I push it back and forth.
There are gaps between rubber and metal.
