I have an interesting problem. My gauge needles start dancing across my dashboard when my car is in motion. They settle down after 10 minutes or so. I have no idea if this is an electrical problem or something with my ECT sensor. It usually goes haywire when I start the car when it is hot outside.
I linked the video to show what the needles are doing.
Thanks a bunch
Nick Eklund
1998 S70 NT Dancing Gauge Needles w Video
- Year and Model: Many Volvos
- Been thanked: 76 times
That's wild. My guess is a bad ground since they are all going nuts but I suppose it could be a cluster problem as well.
Bad ground. The speedo and the tach are getting inputs from different places, so either they share a common ground or there is a bad connector to the cluster
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I'm thinking bad connection at or in the cluster. The grounds that these share with other things would make...well, other things...go crazy.
What's the CEL for? Speed sensor or crank sensor by any chance?
'98 S70 T5
2016 Chevy Cruze Premier
Hi Blackburn,
What does CEL mean? I have the check engine light on and I check saying it was a evap gross leak but it could just be the gas cap problem. Where is the ground located inside the instrument panel?
Thanks
Nick
Thanks
Nick
I just got the abbreviation right after I posted my reply. Doh! I have a code reader and the only code that came up was the evap one. How hard is it to fix the ground inside the instrument panel?
Thanks
Nick
Thanks
Nick
jblackburn
Lee or abscate could tell you where it's grounded. I was only saying that I think a shared common ground between the RPM/ABS/speed sensors would freak other things out and throw codes rather than just having the instrument cluster go haywire. When one of my speed sensors was giving a flaky resistance, the car turned on the ABS/tracs off lights.
I was curious about the check engine light to see if it was any code that might be related to one of these two sensors, but if it's just an EVAP code, don't worry about that for now.
I'm thinking it's a bad connection at one of the 2 plugs in the back of the instrument cluster or a bad solder connection on the pins inside.
'98 S70 T5
