2005 S60 Transmission dip stick and exhaust?
We have a 2005 S60, non-turbo, automatic. The transmission does not have a dip stick. Is this correct? Is this a "lifetime" transmission fluid, or what? There is also a vibration noise in the exhaust system when you start the car and when you accelerate from a stop (it sounds like metal vibrating). I looked at the heat shield but it didn't seem to be the source. There is also something that sounds like an acorn rolling inside the exhaust pipe. Could a piece of the catalytic converter have broken loose and be inside the exhaust pipe? Could the vibration noise be something wrong with the muffler?
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
draser
- Year and Model: 2005 S60 2.5T
- Been thanked: 2 times
My '05 turbo does, not sure if you have a different tranny. Kinda burried down in engine depths there... For the exhaust noise it sure sounds like a shield. I'd get under there and shake exhaust best you can to pinpoint.
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
JDS60R
- Been thanked: 3 times
Remove the plastic hose that goes from the top of the radiator to the airbox. Look below to find the lower radiator hose. Follow the rad hose from the rad to the motor. As the lower rad hose passes by the front of the trans you will see the little yellow dipstick. It is easier to find it the first time once the engine has cooled off.
- ds1.JPG (50.28 KiB) Viewed 1765 times
- ds2.jpg (2.32 KiB) Viewed 1765 times
- ds3.jpg (7.6 KiB) Viewed 1765 times
Retired
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As mentioned above, check for the tranny dipstick with cold engine, so you don't burn your hands.
The middle silencer has a protection plate that can rust on one side while still being attached on the other one, so it will rattle. Best is to grab a longer stick and with the engine running touch the exhaust shields under the car to locate the rattle. If the catalytic converter is broken inside, it can also rattle (can be replaced with a used one from a scrap yard).
- 2387 Views
- 1314 Views
Last post by Tedders
- 1951 Views
Last post by Teddy1975
- 2386 Views
Last post by grammagrace
- 739 Views
