Automatic Transmission Dip Stick
Bigwood1
Year and Model: 2004 C70 LPT
Post by Bigwood1 »
Finally found the Auto Transmission Dip stick but it Wont come out....is there a trick?
Bigwood1
Post by Bigwood1 »
On a 2004 Volvo C70 LPT - Finally found the Auto Transmission Dip stick but it Wont come out....is there a trick?
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
It's probably just stuck on due to not being used much (I'm guessing?). I'd try soaking the seal with some penetrating oil or something for a while and then see if you can gently twist and break it free. I'm not familiar with 2001+ models, but if it's anything like the older ones, the danger is that if you're too forceful, you could snap the handle off and let the rest of the stick drop down into the trans.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
If you are having a hard time reaching it, remove the cold air snorkel first. Then man up and pull it outta there!
1996 855 R,
2010 V70 D5,
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
It is held in with a rubber seal. You pop it out, not lift it out ... catch the drift?
Active
Past
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
MDK here...so, they all get stuck. Just twist, carefully, left and right till it breaks the seal. It has an o ring that dries out. Pita..why, when we pay 30,. 40,50,000$ for a Volvo we can't have a METAL DIPSTICK!!!
Has thanked: 1609 times
Been thanked: 4064 times
Fro my 2007 on you don’t even get an engine dipstick with BMW...just a “ send dealer money” notice
