1994 volvo white smoke, low coolant
daversm
Year and Model: 850 1994
Post by daversm »
Im getting white smoke from the hood of the car, I've been getting the smoke for a few days now but I've been neglecting it because of time restrictions. Today the coolant light came on. Should I inspect for visible leaks for coolant? Where should I start with this?
The smoke starts to come after the car is warmed up a bit, and persists even at idle.
I'll inspect the oil the next chance I get.
Could this be the head gasket?
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Sounds like water may be hittting the exhaust system on its pathway to the ground. There is a coolant pipe running behind the exhaust manifold made from approx 25mm metal tube. Is this a turbo or non turbo?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
daversm wrote: Should I inspect for visible leaks for coolant?
Not sure how to respond to this question.
I doubt it's a head gasket issue.
daversm
Post by daversm »
this is a non-turbo
precopster
There's a large o ring seal at the end of that water pipe just behind the water pump that may leak though I've only read of one instance. A more likely leak source are the heater hoses and the likelihood of a clamp biting through them.
Also the heater hose coupling at the firewall has small o rings that may begin to leak.
