What Type Coolant?
Alwick
What Type Coolant?
Post by Alwick »
Forgive my ignorance, but.
It's a '98 V70, the coolant level is above Min., but below where I'd like it to be. What type of coolant can I use to top up? The manual says "Volvo", so I'm thinking I need to get it from a dealer? Is there an alternative?
Also, do I need to purchase wiper blades from a dealer or is there somewhere else. Thanks.
'98 V70 GLT
White850Turbo
Post by White850Turbo »
Any coolant that is ethylene glycol based that is not labeled "Dex-Cool" will work. I think Prestone has one that is universal as it can be used for any make and model of car.
-Sean
1998 S70 T5 (Almost Stock)
Ghassan
Post by Ghassan »
White850Turbo wrote:Any coolant that is ethylene glycol based that is not labeled "Dex-Cool" will work. I think Prestone has one that is universal as it can be used for any make and model of car.
What is wrong with Dex-Cool? I believe this is the orange fluid? What can happen if you use it?
98 S70 T5 Auto
03 540i 6sp
Jot
Year and Model: C30 2010
Post by Jot »
I have been told to use a NON PHOSPHORUS antifreeze.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Yes, stay away from that stuff...the stuff you want is the flourescent green/yellow looking stuff. All compatible antifreeze will say "good for any radiator," or "will not harm aluminum radiators" on it. You don't have to buy the expensive Volvo stuff.
robert213
Post by robert213 »
Ghassan wrote: What is wrong with Dex-Cool? I believe this is the orange fluid? What can happen if you use it?
Dex-cool?? Just run a Google search on Dex-cool. Whatever you do, do NOT mix orange Dex-cool with the green stuff in your car.
I like Peak and Zerex.
robert213
Post by robert213 »
Jot
Post by Jot »
Why use a product owned by GM ?
