2000, S70, GLT SE, Rough Idle - Initial Start Up
I have been having an issue with my S70 during initial start up. Recently I have been having intermittent rough idle at start up. Wasn't happening all the time and it would resolve itself in 30 seconds or less and then re-start fine the rest of the day. The problem would seem to occur after the vehicle would sit for a while. Many days it would start fine in the morning and the problem would occur in the evening when leaving work. I have attached a quick video to see if anyone else has experienced this. As of yet, no codes or CEL.
2008, C70, 44,000 miles
2000, S70, GLT, 67,000 miles
1995, 850, GLT, 144,000 Miles
1996, 850, Turbo, 226,000 Miles (TMU)
I'll have to try to attach another video clip later. I didn't realize .mov extensions were not allowed. The video basically shows the engine stumbling and then clears up and runs normally.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Check the fuel pressure at the rail (there's a blue cap at the throttle body side of the fuel rail) after turning the key to position II but before starting the engine.
'98 S70 T5
2016 Chevy Cruze Premier
I have the same problem. V70 2000 runs fine and then some days the car will die. Sometime their is fuel in the fuel rail and some time no fuel. I wait 30 seconds or so and car will start and run fine. Any suggestions?
jblackburn
Do you hear the fuel pump run every time the key is turned to position II before starting? Make a habit the next few days of turning the key there first, listening, then turning to start.Kfbtaz wrote:I have the same problem. V70 2000 runs fine and then some days the car will die. Sometime their is fuel in the fuel rail and some time no fuel. I wait 30 seconds or so and car will start and run fine. Any suggestions?
If you hear the fuel pump sometimes, but not others, replace the fuel pump relay and see if it solves your problem.
'98 S70 T5
- 3395 Views
Last post by Ou2mame
- 38 Replies
- 12577 Views
Last post by bmdubya1198
- 1164 Views
Last post by nthnnxn
- 22 Replies
- 5099 Views
Last post by unggthat
- 17 Replies
- 1587 Views
Last post by vtl
