I have completed a timing belt replacement and I used the rear cam lock tool to stabilize the cams. The cams are aligned to sprocket timing marks and I have the rotor positioned at cylinder 1. On the intake cam the part number is on the bottom, the exhaust cam the part number is on the top.
I need help on the cam shaft position sensor wheel orientation. It can be installed one of two ways.
thank you
1998 V70 CPS relucter wheel orientation
- Has thanked: 312 times
- Been thanked: 818 times
Hey, we trust you not to waste your time, anyway!
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
If you did seal then tool was required.
The CPS reluctor will only lay flat on camshaft end when fitted properly. It will sort of fit 180 off but the bolt will not start without some difficulty.
If you look at reluctor and end of cam you can match the offset notches to the offset slot on cam.
- 3050 Views
- 1324 Views
Last post by 98v70dad
- 1680 Views
Last post by ogatrulle
- 2997 Views
- 1367 Views
Last post by northern_dweller
