Better half caught a chunk of Ice and the OE styling spoiler needs to come off to be repaired or replaced. It appears to be held on with some kind of plastic rivet. I'd like to not add to the damage, how to these fasteners come off?
Thanks!
06 S60R Ft. Spoiler(Lip\Winglet) damaged need to remove
TacklaNHL
- Year and Model: Volvo S60R 2006
- Has thanked: 1 time
- Been thanked: 4 times
I believe you're going to need to drill through the middle of the rivet. Volvo can get your replacements if you're interested in OE... but basic rivets will work too. I put some beafier rivets into mine when re-installing.
These winglets are a PITA, no doubt. But they look great. Many owners try a myriad of different attachments.... but I stick with the 3M double-sided sticky tape (get the good stuff, not the cheap stuff) and the rivets. Use a heat gun to warm the bumper, and the winglet, as you apply the tape, and then warm it as you're applying it.
Hope that helps.
Hope that helps.
2006 S60R AWD M66 Passion Red -- Denver, Colorado
2016 XC60 T6
2019 XC90 T6 R-Design Polestar
Pre-Installed VIDA laptops for sale, plug-n-play, DICE, Mongoose, Boot&Go, lifetime warranty, thousands of satisfied customers!! DiagLaptops.com
2016 XC60 T6
Drilled the rivets and fought the adhesive one down!TacklaNHL wrote:I believe you're going to need to drill through the middle of the rivet. Volvo can get your replacements if you're interested in OE... but basic rivets will work too. I put some beafier rivets into mine when re-installing.
Hope that helps.
Wonder what will remove the remaining adhesive while leaving the paint...
Thank You for the tip!
TacklaNHL
GooGone breaks it up a bit.... but what always works for me is just get a dry rag, and rub it... it'll start to curl up on itself and you just push it off.
Yes, tedious.... but at least it's small enough area.
2016 XC60 T6
2016 XC60 T6
I tried working on it like you describe and shortly gave up and went to the local NAPA, picked up a quart of "3M General Purpose Adhesive Cleaner" $20.00. I also cut a piece of pine to use as a scraper.TacklaNHL wrote:GooGone breaks it up a bit.... but what always works for me is just get a dry rag, and rub it... it'll start to curl up on itself and you just push it off.
Liberally coating the tape residue letting it sit for a few minutes and then scraping it with the wood block quickly removed the goo, didn't hurt the paint at all and didn't even touch the three globs of hard black rubber that space and also hold the Winglet on. I carefully cut off them off with a razor blade and the whole area will be covered up when I decide what to do permanently this spring.
Two side notes:
My wife actually noticed a change in the cars handling after the Windlets were removed.
I discovered that the plastic covers on the fog lights are missing and the wiring broken and... ah... Shambolised , ya that's it completely shambolised! Now to find two new back covers and then rebuild the wiring.
C
- 4093 Views
Last post by otis44
- 7010 Views
Last post by SuperHerman
- 3953 Views
Last post by Juan62
- 5041 Views
Last post by jimmy57
- 3047 Views
Last post by FLXC90
