1994 850 Head Gasket Or More?
petek153
- Year and Model: 1992 940T
So I'll start by telling the story that I was told and would like input as to how bad do you think this is. Son had the car on the highway (has a heavy foot) so was going 70 +would be my guess said the car temp gauge starting getting high and then car shut down. When I got there car was still smoking could smell the antifreeze so figured blown hose overflow tank was empty. Threw some in the tank started to crank car saw it spraying out from heater hose so didn't even try to run it . Outside air temp 20 and snowing so just called the tow truck. After getting it in my garage repaired the hose and started filling tank and had my son start car while I was going to add antifreeze while it ran. But what happened is it starting pumping like a gusher out the overflow tank and you could smell exhaust out of tank. So I believe it's the head gasket but how much worse do you think it might be? Temps are winter norms here and hate to start if its more than a head gasket it will be done in the driveway or should I just write the car off has 184k miles on it. Thanks for your input.
Reason: Clarified title - please, no ALL CAPS in titles
92 940 turbo
93 850 GLT sold
94 850 GLT
96 850 GLT my parts car (:
96 850 T_BONED ):
97 850 BASE
93 850 GLT sold
94 850 GLT
96 850 T_BONED ):
97 850 BASE
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
It is a pressurized system. Sometimes the expansion tank caps fail. If you are really lucky, you shut it down before you had a serious overheat condition and a new cap and several ounces of coolant will solve all of your worries. Let's start with Occam's razor and take care of the potentially simple stuff first before imagining complex problems. Sometimes folks do get lucky -- notice I said folks, not me. . . Get a Volvo cap. Aftermarket ones can be dodgy. I'd also be prepared to replace the Engine Coolant Temperature sensor ECT, and thermostat as cheap insurance.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- dosbricks
- Year and Model: '96 855, '98 S70
- Been thanked: 4 times
It is probably not worse than a head gasket and the required truing of the head. So what you decide to do with the car will probably depend on its overall condition and whether it has already had a lot of work invested in it. If your son is available to help with the repair in Connecticut winter, that could be a teachable experience.petek153 wrote:....But what happened is it starting pumping like a gusher out the overflow tank and you could smell exhaust out of tank. So I believe it's the head gasket but how much worse do you think it might be? Temps are winter norms here and hate to start if its more than a head gasket it will be done in the driveway or should I just write the car off has 184k miles on it. Thanks for your input.
petek153
Car itself is in good shape front ends rebuilt, all new brakes and rotors, strut mounts etc... of course he was going to head back to Tx with it today but had to fly because of this.Better here than on the road somewhere. He's in the service so kinda on my own on this rebuild hopefully warms a little so I don't drop too many bolts due to numb fingers.Won't order parts till I tear it down in case it's more and not worth repairing it will become a parts car
92 940 turbo
93 850 GLT sold
94 850 GLT
96 850 T_BONED ):
97 850 BASE
93 850 GLT sold
94 850 GLT
96 850 T_BONED ):
97 850 BASE
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
There is no doubt that the head gasket is blown. The issue would be if there is more damage. You could probably install the cap tight and start the car to see which cylinders are leaking. If the car shut down while running, it either fouled out the plugs or the block got so overheated that the pistons seized.
Now for the $10,000, what caused the overheat? Most people THINK the blown hose caused the issue, however in a lot of cases, the overheat blew the weakest hose, which in your case was the heater hose.
Another thing to consider, did the motor blow coolant into the exhaust? This can cause a cat issue.
I suggest that you do a compression test. If more than 2 cylinders are reading low, replace the motor.
- 18 Replies
- 5820 Views
- 472 Views
Last post by erikv11
- 627 Views
- 1414 Views
Last post by s10lowrider1994
- 3396 Views
Last post by rspi
