Hello all.
B230f, Automatic trans
There is a vacuum hose that goes from the ignition control module to the intake manifold. At the intake manifold the vacuum hose connects onto a nipple on a bolt that screws into the manifold. At the ignition control module, the hose connects to a nipple on the bottom part of the module facing the front of the car. What is the function of this vacuum connection?
Matt
1986 240 DL Ignition control module vacuum hose
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
As the engine increases in RPM, for a given load, the timing must be advanced since it takes so long for combustion to ignite. If timing is advanced too much, denotation will happen; if timing is decreased, less power and less mpg.mhgreen wrote:....willing to explain.lummert wrote:Vacuum controlled timing advance?
It takes a timing light to evaluate if advance is working or not, and iirc, the vacuum timing advance will not start working until after 1,000. There is also a "mechanical advance" as based upon engine's RPM.
So, timing advance is part RPM based, and part vacuum based on your Volvo.
Here's what a LH 2.2 curve looks like
