2004 XC90 Getting error code P0011
Androck1579
- Year and Model: XC90 2004
While on the way to work the other day I a warning came up STOP ENGINE OIL PRESSURE LOW STOP ENGINE. I checker the oil and it wass kind of low so I topped it off. After doing so, the warning went off then the check engine light came on. I borrowed a ODB11 from one of my friends and attached it to the port it came up with Error P0011 Cam shaft position, Actuator A- Bank 1 and Timing Over-Advan. I just wanted to know if there was anything that I could do to solve this problem. If anyone has run into this problem and can help me out that would be great. Thank you
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
First off, don't run the engine, this warning says the cam and crank positions are not within parameters. presently, it may run, but it may have skipped a tooth on your timing belt.
Get it checked immediately!!
Otherwise you run the risk of bending all your valves, and rebuilding the top end of the motor.
If things are great, maybe your cam position sensor is failing, but the above warning is what it is there for. Most likely your timing belt and corresponding parts need replacement. How many miles? what history etc? Let us know how you fare.
Current Volvos:
- 3099 Views
Last post by jbkeene
- 16 Replies
- 12103 Views
Last post by Austingrayy
- 643 Views
Last post by Cal01s80
- 1910 Views
- 2190 Views
Last post by Eikeg
