'02 2.9 - Rough Acceleration, Exhaust Noise, P0011 & P0016 codes
ashly.ydr
Year and Model: 2002 S80 2.9
Post by ashly.ydr »
Hey, everyone! I've had a pretty rough issue come up on my 2002 S80 2.9 today. Was taking a usual drive, nothing out of the ordinary, and began experiencing loud exhaust-like noises upon acceleration. The acceleration became slow and unsteady. Some rumble and hum at idle. Also, a slight "jump", for lack of better word, while maintaining an even 48/50 mph.
My husband read a P0011 code on the first reading, and now it continually reads a P0016 code, both relating to the cam. Also, the timing belt was replaced just about 30,000 miles ago.
We're really at a loss here, and appreciate any help! We're currently most interested in what the correlation between this loud, exhaust-like sound and the cam codes are. My husband generally does my repairs, so this vehicle is frequently maintained.
Thanks in advance!
-Ashley Reynolds
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
It is issues with the Variable Valve Timing (VVT)
Three things that can cause both codes are:
  • Low oil pressure
    Poor oil quality
    Defective reset valve
You might start with an oil and filter change. Use a good grade of oil and a quality filter.
Active
Past
RickHaleParker
  • Low oil pressure
    Poor oil quality
Active
Past
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Been thanked: 33 times
Post by Cees Klumper »
Probably nothing, but the exhaust-like noise would have me checking all the air ducts (assuming you have a turbo engine) involved in the turbo system. I had a v6 turbo once pop an air intake hose, and that resulted in the noise you describe. Good luck with the repair.
Austingrayy
Year and Model: 2008 s40
Has thanked: 1 time
Post by Austingrayy »
I have a similar issue with my s40 2008, code p0011, rough idle, starts once, moves fine but idle poorly, timing belt replaced, oil changed , still same issue and bad fuel economy
Austingrayy
Has thanked: 1 time
