00 V70 XC SE What's up with the security screws on the MAF?
This topic is in the MVS Volvo Repair Database » What's Up With Volvo's Security Screws On MAF?
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
Bought a new MAF and what a difference! Easy starting, smooth running.
But what's up with the 5-point security screws that mount the sensor? Why does Volvo think its so important to not unscrew it? It's just a sensor inserted into a plastic collar.
I ask because my replacement MAF assembly has a diameter that is a bit too large to fit into my filter housing and air duct (I had to duct tape it in place). I want to put the new sensor into the old assembly, but there are those darn 5-point security screws. Why does Volvo think that never removing that part is so critical?
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Oh,
BMW does the same thing.
I think they (Volvo, BMW etc.) do not want the Jack and Joe fooling around with the MAF.
Very much like the TV Cable company (such as Cox, Comcast, etc.) places a security screw on the cable Box mounted outside of the home.
I agree it is goofy. This is a deterrence to the average shade-tree mechanic who does not have the security Tox keys.
Anyway, they should get rid of the security Torx, a waste of their time.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
instarx wrote:...I ask because my replacement MAF assembly has a diameter that is a bit too large to fit into my filter housing and air duct (I had to duct tape it in place).
You should have bought OEM Maf sensor.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
instarx
Has thanked: 1 time
Post by instarx »
misha wrote:You should have bought OEM Maf sensor.
Lol, when I win the lottery all my 15 year old cars will get OEM parts. I promise.
2011 XC60 - sold
misha
Post by misha »
You're lucky that with aftermarket maf your car even runs.
If you carefully read other members post....your aftermarket maf will not last long and sooner or later you must buy oem one.Doesn't matter is it new or used as long as it is OEM Bosch.
Good luck!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 2197 times
Been thanked: 1851 times
Not sure that it is Volvo or BMW that puts the security screws in but Bosch. I have a Bosch one and it also has the security screws in it. I have a set of security torx tools, but it doesn't work on this screw as it is wider and longer than others I have worked on. It would be easy to modify the torx bit to fit though.
DrJammer
Year and Model: 2000 V70XC - 195k
Has thanked: 1 time
Post by DrJammer »
A single security torx is not that much in dollars, but understandably annoying. The MAFs I worked with on my non-turbo P2 did not have the security bits. You could always use small vise grips to remove and put in matching non-security torx screws, and some I have heard are plastic and you can snap off the pins and use a traditional torx bit.
And after much reading on this site, I went with used OEM MAF and had no issues. Good luck.
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Contact your local Snap-On rep and he will provide a Toledo set. If nothing else you get a nice bit adapter and extension 8-)
Instarx did you buy a Dorman or Delphi brand insert?
instarx
Has thanked: 1 time
Post by instarx »
DrJammer wrote:A single security torx is not that much in dollars, but understandably annoying. The MAFs I worked with on my non-turbo P2 did not have the security bits. You could always use small vise grips to remove and put in matching non-security torx screws, and some I have heard are plastic and you can snap off the pins and use a traditional torx bit.
I found a 5-pt torx security set for $10 on Amazon, but its just the annoying futility of having to get it that bugs me. I tried the vise grip thing, but they sneakily made the screws round so you can't get a grip. I just cannot figure out what's so darned important about not unscrewing those two screws! LOL.
I went with an AIP Electronics MAF, which I chose for price.
I do recognize the importance of OEM when the parts are safety related, but a MAF is just no big deal, and the difference in price was $130. The car runs 100% better with loads of power I had forgotten I had. I was afraid I had another bad ETM.
2011 XC60 - sold
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
All the parts stores sell the bit sets also for around $10. OEMs /suppliers used tamper-proof on critical systems-critical being the ones the Governments required, like emissions control equipment.
Current Volvos:
