Hey everybody. New guy to Volvo here. I purchased a 2000 S80 with blown head gasket. Started working on it this morning. There is coolant in No. 4 cylinder.
I've removed all valve cover bolts except the star bolts. Do I have to remove them to get the cover off? I'm not sure it there holding the cams in place. Is there a preferred method for removing cover or should I just pry it off? I don't want to bend or break anything. Thanks for the help. This is a great site.
2000 S80 Head Gasket
Florida Wheel
- Year and Model: S80 2000
MyS40T4
- Year and Model: S80 T6 2000
Hi,
Have a look at this:
https://www.matthewsvolvosite.com/forums ... 11&t=35482
You probably don't want to do any more disassembly without following the process and knowing how it all hangs together.
I'd search the forum for "cylinder head removal" or something similar.
Cheers
Cheers
Florida Wheel
Thanks. Yes, I've been looking through the forum. Saw something that said the cams are held in by the valve cover so I'm not sure if those star bolts should be removed.
Florida Wheel
1999 Ford F-250 SD PSD
1977 Olds 442
2000 Volvo S80
1977 Olds 442
2000 Volvo S80
precopster
- Year and Model: Lots
- Been thanked: 128 times
The "star bolts" are torx bolts that hold in the adjusting shims for the tappets. Don't disturb them.
The 46 10mm bolts will separate the two halves and expose the head bolts.
Prying, hitting with a hammer on the prying lugs and mostly cursing will get it off.
Florida Wheel
Excellent! Thanks for the help.
Florida Wheel
1977 Olds 442
2000 Volvo S80
1977 Olds 442
2000 Volvo S80
Florida Wheel
Got it.
Florida Wheel
1977 Olds 442
2000 Volvo S80
1977 Olds 442
2000 Volvo S80
- 18 Replies
- 6010 Views
- 509 Views
Last post by erikv11
- 2603 Views
Last post by precopster
- 2041 Views
Last post by crussell83
- 771 Views
Last post by SuperHerman
