Neither the low or high beam operate on the left/driver side. I have done the following.
1. Swapped the working bulb on the passenger side with driver side. Again, passenger side worked so both bulbs are good.
2. Checked the voltage in 17/18 under the hood.
3. Checked / swapped the fuses in 17/18 under the hood.
4. Checked the voltage in 30/31 in the passenger compartment.
5. Checked / swapped the fuses in the passenger compartment.
6. Checked the voltage to the back of the headlamp assembly and all checked out OK.
7. Swapped the working bulb socket on the passenger side with driver side. Again, passenger side worked so both bulb sockets are good.
Driving me crazy! Any help would be greatly appreciated!
2004 XC90 Left/Driver Headlight Problem
- 722 Views
Last post by Edward1227
- 741 Views
Last post by Vova585
- 11 Replies
- 668 Views
Last post by aaronlife
- 2954 Views
Last post by xcrico
- 5851 Views
Last post by Sasha0395
