1999 v70xc p0115 dtc
19999v70xc
- Year and Model: 1999 v70 xc awd
I have a 1999 v70 xc awd with a p0115 dtc just got it back from the shop because the ses light was on they say it was an 02 sensor code they fixed the connector and road tested but as i turn in the driveway I get the p0115 any thoughts or help is appreciated also this is the third time its been in for the 02 sensor starting to wonder about these guys
- Year and Model: Many Volvos
- Been thanked: 76 times
P0115 is an engine coolant temperature sensor code. It isn't a huge deal to change it if is in fact is bad but standard operating procedure is to change the thermostat at the same time since it is right there.
Typically with a bad ECT sensor the gauge doesn't go to its normal 3:00 position and the car can be difficult to start. The fuel economy suffers as well.
The sensor is a bit pricey for the OEM but OEM is what you should use. Before changing it though check the connector to make sure it isn't corroded or loose. The connector plugs in just behind the power steering pump.
19999v70xc
I have all of those issues thanks for the reply guess its time for a t stat and sensor will keep you posted if its a fix or not
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
+1 on Lee's tip to check the connector. If you're lucky, it is just badly corroded and a shot of contact cleaner and some dielectric grease may have you back on your way. I don't have that kind of luck, but some do.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
19999v70xc
tried the contact cleaner no such luck the sensor its self is actually leaking slightly going to replace them both this weekend looks pretty easy to do
19999v70xc
replaced t stat and sensor but now have an 02 sensor code again its been replaced 2 times and still keeps coming back do I need to have the pcm re flashed as well or could it be a bad sensor again I appreciate all the help
What is the code number? Most oxygen sensor codes are not due to a bad oxygen sensor.
19999v70xc
its a p0134 and its not showing any activity does it need to be an oem sensor
Some people have managed with the Bosch Universal but the splice box is known to cause problems. The Beck Arnley and other aftermarket brands never seem to work properly though. I believe the OEM brand is a Bosch sensor for the 1999 ME-7 system but that should be checked for accuracy. In 1999 some models started using Denso sensors but I think that was exclusively for use with the Denso ECU.19999v70xc wrote:its a p0134 and its not showing any activity does it need to be an oem sensor
In either case get the OEM equivalent with the OEM style plug. It is unusual for the sensor to fail completely that quickly.
19999v70xc
well I think they used an aftermarket one when it was replaced I did find the bosch # 15667 on rock auto with the oem plug looks like the one was curious about the band name though I appreciate the help Im very frustrated
- 4547 Views
Last post by kutzsche1
- 613 Views
Last post by precopster
- 639 Views
Last post by 09volvos40
- 1905 Views
Last post by sd4sweet
- 2501 Views
Last post by lummert
