dumb question - radiator splash guard bolts
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
Does anyone know the thread of the bolts that hold in the splash guard tray beneath the radiator, behind the front bumper? I lost the bolts a few weeks back and I'm gonna move soon, so I'd like to reinstall the tray.
EDIT: if I'm not mistaken, this takes a 10mm socket. It should be an M6 bolt then:
https://www.boltdepot.com/fastener-info ... -size.aspx
If nobody else knows 4sho, I'll pick a couple of these up and tell ya how it works out.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
I can confirm they use a 10 mm wrench. Fo sho on that part.
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
M-6 sounds right. I lost one and just grabbed another out of and assortment of European/Asian bolts that Advance sells in a plastic divided box. Those a pretty much all M-6 and M-8 in various lengths and it wasn't one of the large diameter ones. The heads on the assortment rarely match the OEM though.
Juan62
Year and Model: S70 T-5M 1998
Been thanked: 2 times
Post by Juan62 »
The air bolt guide; P/N 985743, 968478, F413, M6 x 1.0 x 12mm
In case you need the expanding nut to the air guide and frame: P/N 987282, 6mm x 1.0mm thread outer.
P/N 985743, 968478, F413.
Air Bolt Guide.jpg (21.58 KiB) Viewed 1916 times
P/N 987282
P/N 987282
Volvo Expanding Nut.jpg (18.78 KiB) Viewed 1916 times
98 S70 T5-M Brick for life
j-dawg
Post by j-dawg »
It's finally dryish outside, so I installed that splash guard. M6 bolts worked fine. I'd recommend getting bolts with a length shorter than the 12mm I used, if you can - my ratchet was interfering with the washer fluid reservoir.
Juan62 wrote:The air bolt guide; P/N 985743, 968478, F413, M6 x 1.0 x 12mm
On my car, that hole is threaded directly into the body at the seam, unless I totally missed something.
