2001 V70 XC Transmission Cooler Line
On my lower transmission line on the end that bolts in to the transmission the bracket that bolts in has come unattached. Seems like when I tightened the bracket that is half way up the line it caused the lower bracket to come unattached. Has anyone repaired this without having to purchase a new transmission cooler line? Any help or ideas are appreciated.
- SuperHerman
- Been thanked: 207 times
Sounds like you broke the weld. As I recall the tube is welded to a bracket that has a 10mm bolt that attaches the line to the throttle body cover. You can see if you can find someone to reweld it for you or buy a used one at a junk yard.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
There are two brackets on this cooler line...
...1,
or 2 ?
...1,
or 2 ?
I broke the weld on the first photo shown above the one that screws into the transmission. Maybe a can use a small worm drive clamp to hold the broken bracket to the hose. (and maybe some JB Weld) Anyone have any idea how I might keep the ATV fluid from draining out while I repair it? Anyone used something to plug the hole in the transmission so I don't lose the $70 of ATV fluid I just put in?
- regent
- Has thanked: 2 times
- Been thanked: 12 times
Why not just pull the drain plug and let as much as you can out (the maximum that will drain is 3-1/2 qts if that) Have 4 qts of new fluid ready to refill when you're done with the line (I would consider anything drained to be 'unclean'); this will set you back short of $25 (not $70) and you will also have some fresh fluid in there.
If you ensure good cleanliness you may re-use the drained fluid (but I still wouldn't)
An alternative method would be to use a rag for a plug, and then replenish the spill and drip only
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
xHeart
The hot glue gun will not repair it.wrldky wrote:I broke the weld on the first photo shown above the one that screws into the transmission. Maybe a can use a small worm drive clamp to hold the broken bracket to the hose. (and maybe some JB Weld) Anyone have any idea how I might keep the ATV fluid from draining out while I repair it? Anyone used something to plug the hole in the transmission so I don't lose the $70 of ATV fluid I just put in?
Drain the fluid first as regent says, put the plug back on with new seal.
Then remove the cooler line and take it to bench.
Clean it, and take a closer look.
A weld is your best option -- ask a muffler shop.
Not sure if an off-the-shelf compound such as JBWeld will hold it for longer then a week.
With these many miles, I say, replace the line.
Thank you for the advice. The only reason I didn't want to drain the transmission was because it took me so long to fill it back up thru the dipstick tube. The reason I don't just buy a new transmission cooler line is because it probably will cost about 1/3 of the value of the car. ($100) I believe it is good advice to remove and weld. I will keep you posted.
- 1651 Views
Last post by SuperHerman
- 2632 Views
Last post by oragex
- 2289 Views
Last post by fitz548
- 1557 Views
Last post by tryingbe
- 16 Replies
- 7654 Views
Last post by erikv11
