1994 850T Camshaft Position Sensor Replacement
cBobs94850T
- Year and Model: 850 1994
I have read and watched the Tutorials on this repair. The comments are the sensor should just pull straight out. I cannot pull the sensor out, it is loose and I can move it clock and counter clock wise about an half an inch but it won't come out. A little help Please
- Has thanked: 311 times
- Been thanked: 817 times
Give it a little prying action with a screwdriver between the sensor and the metal of the valve cover, I have done that. Be careful though with the soft aluminum. And if the CPS has a black plastic cap you don't want to pry that off; some are all metal some are half plastic.
cBobs94850T
Thanks erikvll I did try prying and no luck, is it possible that whatever that passes through the sensor in the way. I have the sensor with the black plastic cap.
There isn't much inside, that's an odd one, shoot:
I did ruin one once by prying, I separated the black plastic from the metal. Maybe try to pry only metal on metal, go around it with little nudges so it is coming straight out.
cBobs94850T
Thank you erikv11 I finally got it out it last night, I tried wiggling it back and forth while pulling on it and it poppet right out. the picture you show look just like mine and the replacement Bosch unit shown on the left. Was to cold in in new England to finish the job
Thanks again
Thanks again
- Been thanked: 504 times
Great!
There is a cardinal rule in car repair:
- Whenever you need to remove an old part and run into problems, simply look at the new part (that you plan to install), it will give you a clue as to how to remove the old part.
- If possible, always, always test the new part before installation. Let's say you need to install a new water pump, spin it first, check the mating surfaces, check for any obvious defect before installation. In your case of the CPS, it is not possible to test it before installation.
Just my 2 pennies...
- 756 Views
Last post by cBobs94850T
- 2595 Views
Last post by Luzanov345
- 528 Views
Last post by jackissocool
- 1192 Views
Last post by Ozark Lee
- 1833 Views
Last post by batman00024
