2001S60 Turbo Transmission swap to newer model
chv3ch
Year and Model: S60 2.4T 2001
Has thanked: 3 times
Post by chv3ch »
I have the dreaded 01 S60 transmission with stop neutral feature. The car has about 140k miles on it. I have had a little trouble from the transmission in the past, but could always make it happy by changing the fluid. It is no longer happy :cry:
Is it possible to put a later model transmission into the 01? Perhaps an 02 or 03 transmission? Does the transmission have to come from a turbo model?
Is there a way to remove the stop neutral feature from the 01 trans without visiting the Volvo dealer?
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
You can fit an '02 if it has the same valve body but you will need to get donor's VIN and check this all through Vida.
There are at least 2 or 3 different valve bodies and you can't interchange an AWD trans into a FWD or non turbo to turbo or vice versa.
Dealer is required for transmission software update unless you own a Dice tool and contact Henry (doublebug)
A refurbished valve body may just sort your problem for under $600. Try Reamman or VBX.
What are the symptoms?
chv3ch
Post by chv3ch »
The symptoms are shifting in and out of gear while stopped. It gets worse the longer I drive (especially in long traffic jam). Also it is starting to downshift hard after letting off the accelerator. The hard down shift worries me the most because this is new. I have been able to ease the neutral shift by changing fluid in the past.
Can the valve body be replaced by do it yourselfer?
I am looking into Dice tool. Whatever it takes to prevent going to dealer :)
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You need to update the software first
It seems that you are running the original stop neutral software which not only is it annoying, it DESTROYS transmissions
Get thee to a dealer ASAP and have the latest software downloaded, VIDA will do you no good unless you have a means to buy the software.
If it has the latest, you're in trouble and you need a new or rebuilt valvebody.
Lately we have found that the $150 valvebody cleaning kit (plus someone's labor) suffices and does the trick
