98 xc70 Mud Flap under body
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
Does anybody have the part number or a photo of these ? they mount in front of the rear wheels under the car
Has thanked: 2199 times
Been thanked: 1852 times
Hi northern friend, hope this link works. You need items 17, 22, and 25, as long as the mounting points are part of the rear jacking point. If you don't have them, then you need the jacking point #16.
skloon
Post by skloon »
Sorry don't see a link
Sorry, that is weird as I did attach it! I'll do that again then!!
http://www.volvopartswebstore.com/showA ... egory=7873
Look at part #'s 16, 17, 22 and 25
Part #16 - Jacking pad 9474533 (may not be needed)
Part #17 - Mud flap 9474091
Part #22 - Retainer, black 3521768
Part #25 - Sems screw 977509 (Holds 16 in place so may not be needed).
Adler
Year and Model: 04 XC70
Post by Adler »
Can these be mounted to a FWD v70? I've always wondered why they don't have something to protect the rear end links from road spray.
Anything is possible, but on the AWD cars, they have an additional jacking point with a bracket that these mount to (Part#16). However, if you are creative, there is no reason I can see that you couldn't fab a simple mounting bracket with angle iron and bolt to underside of your car. You may find there are exiting hardware in the area that you could use to mount a bracket to.
Neil
