On my wagon, none of the windows work..the fuse is fine too..I ran a wire from the fuse terminal to the switch where the red wire comes in to feed the whole switch block, and the windows would work fine. There is no cut or severed wires so is there a bad relay or something? and where would that be?
so, just to clarify, obviously the fuse is fine, the switches are fine, they're just not getting any power....even though they should be...
Any ideas?
thanks,
Sean
84 240 power windows problem
seandutrow
- Year and Model:
