1994 850 Ignition Coil overheat
osolanog850
Year and Model: 1994
Post by osolanog850 »
Hi Guys,
nice to say hello again, I have problems with my two Volvos (850 Both 1994). The first one: two cylinders with low compression,
The problems with the other car started with the camshaft position sensor, I changed, and then the car don't want to start, and I tried everything, but the problem that I have now, due to change the camshaft position sensor: is that the ignition coil is heating! I destroy two of them already, I sent the computer to review it and the computer its Ok, but I don't have, let say... spark in the cables that goes to the sparkplug, I change the crank speed sensor, buy another camshaft position sensor, sparkplug cables, ignition distribution rotor, and I have the same problem.... overheat in the ignition coil, and no spark in the sparkplug cable.
'94 850 Manual 39,300 Km
'94 850 Autom 45,000 Miles
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
If the coils are burning up then the problem might be with the "power stage" that drives the coil. It is the trigger circuit that is bolted up next to the coil.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I would have assumed that the OP is swappimg out the coil with the power stage as an assembly. Separating them is hard work as they are individually riveted to the coil frame assembly.
If this OP is separating them and JUST replacing the transformer I guess the results speak for themselves. ....
osolanog850
Hi Guys,
thank you for your replies, like precpster said is a complete unit, does anyone have an electric diagram of the coil?
Regards
Oscar
osolanog850
Camshaft Position Sensor
Ignition Coil
Ignition Coil
Electric Problem (DIMM light)
precopster
When you fit the cam sesnor are you routing the wiring back through a plastic clip on the torque mount?
Most of these clips break off and the cam sensor lead then is allowed to be very close to the high tension leads coming off the distributor. The EMF generated by these leads into the cam sensor circuit COULD result in problems.
osolanog850
Thank you, good tip! I'm not fixing the connector to that clip because I just put all together and do the testing, I will try later today,
I also change the crank speed sensor, do you think that this component could be damage by the ignition coil?
Motor
Motor
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
"...overheated ignition coil + no spark".
Check your ground wires.
Also, check your voltage regulator.
precopster
Replace the rotor button. There is an inbuilt resistor which can break down and draw extra current.
You can't faultrace an ignition system without new components.
osolanog850
Thank you guys!
I spoke with an electrician yesterday, he think that the problem is a ground wire... but we will see on Saturday.
Thank you guys again!
I will post the results
Oscar
