In the picture attached, is it true that the two bolts circled in Yellow are the two bolts to remove in order to get the caliper off for say a rotor replacement?
Also, is the thing circled in Blue the (covered) brake bleeder valve (ie turn it and the brake fluid comes out for bleeding the brake) ?
Also, is that the brake line tube i see near the top of the picture where it comes down and close to the top left yellow circled bolt head? It looks solid. It doesnt hurt to bend that slightly?
Thanks
