1999 V70XC AWD antifreeze leak
tyrendis
Year and Model: v70xc 1999
Post by tyrendis »
Hey guys!
I noticed in the past few months I have been purchasing a large amount of coolant as my sensor light turns on frequently. I checked the other day finally and noticed dripping coming from the passenger side of the bottom of the radiator. However it appears to be traveling there from somewhere else. I am not sure if the leak originates in the radiator or in the line itself. Is there a viable way to diagnose the leak location? I can take pictures if required also
Seaway
Year and Model: 1998 V70 T5 Manual
Post by Seaway »
My car had coolant leaks at the upper radiator hose and at the short hose connecting the hard metal lines to the the turbo (at the firewall). The leaking upper radiator hose was identified by seeing the white reside the coolant left after it burned off/evaporated. You could have a leak at the other end of the hose at the radiator junction. Run the car up to temperature and see if you can see where it is leaking.
I was also leaking a small amount of coolant from my heater core, but I caught it in time and changed that out the other night. Any syrup smell in the cabin?
tyrendis
Post by tyrendis »
syrup smell? like maple syrup? no but there is an odor that I would probably attribute to the coolant. ill have to run it up to temperature after work today
mika
Year and Model: 97 850 NA 98 v70
Post by mika »
He is saying that one common coolant leak location is the heater core (your carpets would be wet). Otherwise, it should be preety easy to find a coolant leak if it is under the hood, just look around. There is a top radiator hose (left side up high, goes to thermostat), and other one snakes around to the right side, connected from bottom of radiator and goes around to the back by the airbox. Most leaks are easy to see. There are other locations obviously where you can leak, just times some time and take a look
Tip: top off with <distilled> water for now.
'92 945 Turbo, 13lb boost on E85 with 54lb injectors, 230k
'98 V70 N/A 174K , Konis Sport + H&R Blue springs,16 inch Solars
'97 855 N/A
Previous: Honda Fit Sport (RIP), Kymco S200 (missed),
'86 244 DL M46 (restored and traded)
tyrendis
Post by tyrendis »
yeah my carpets are dry. I'll take a look later today though
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
Overflow bottle and/or hose going to it. It was a very slow leak in mine for a long time and hard to locate. Hoses are old and clamps come loose.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Has thanked: 1610 times
Been thanked: 4068 times
You carpets can be dry even though there is coolant underneath them. The padding on these cars is really thick and can hold gallons of coolant
There is a tray under the radiator that catches coolant leaks and delivers them to the lowest point, so you cannot reliably locate a leak by the drip position under the car.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
If it is coming from the radiator area, you need to take the big plastic air guide thing out that covers the area from the bottom. It will probably be obvious when you do.
I recently had a pesky leak on my XC from the little hose feeding into the reservoir at the top, even with a new tank and new hose.
In that case the clamp made the difference. For some reason the Volvo engineers decided that a half barb would be enough to seal at the tube connection :roll: . Silly design.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
tyrendis
Post by tyrendis »
850 LPT wrote:If it is coming from the radiator area, you need to take the big plastic air guide thing out that covers the area from the bottom. It will probably be obvious when you do.
I am unsure of the area you're referring to
Seaway
Post by Seaway »
850 LPT is talking about the plastic cover on the bottom of the car that is there to protect the bottom of the radiator and the associated hoses. It's sometimes called the Splash Guard. Your car may not have one as they are known to break off.
