1998 s70 hood wont unlatch on one side
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
Try pulling the hood release and holding it for about 20 seconds.. Mine does the same thing. I pull it, go lift the bonnet a little go back and pull the release again and it should lift.
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
j-dawg
- Year and Model: 1999 V70 T5
- Been thanked: 33 times
You can adjust the latches on each side that hold the hood down, as there's a little play in the mounting holes. Moving the latch down will compress the rubber stops and put the latch in a little tension when the hood is closed, so it will pop when you pull the handle.
At some point the cables have stretched or the latches won't move and you just have to replace the cable, but this is worth trying and it takes very little time.
I have found that if I pull the release handle with my right hand and push down on the corner of the hood with my left at the same time the hood opens. Saves a little back and forth running.
2007 S60R Magic Blue/
2005 S60 2.5 AWD Silver/Black
2001 C70 Coupe HPT black/black 149000 miles
2000 C70 Coupe HPT 132000 miles...SOLD
1994 850 sedan n/a 230000 miles...SOLD
2003 GMC 2500HD Crew Cab
1993 Corvette 40th Anniv Convertible
1960 Corvette
1960 Corvette
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
+1 on latch/bumper adjustments for Stephan: try some spray lube on the cables, sounds like one is sticking.
Current Volvos:
Ludermilch
- Year and Model: 98V70XC 98V70R 01C70
- Has thanked: 1 time
I do a similar action as rubyvette. I pull up on the corner of the hood next to the windshield while reaching inside and releasing the latch. Works every time.
1998 V70XC
2001 C70
1998 V70R
2000 Subaru Outback VDC
Perception Fontana Tandem Kayak
2001 C70
1998 V70R
stephansvolvo
I'll give this a try too. I've been dealing with it for a while now so I just chualk it up a little extra excercise, trust me I could use it.FLXC90 wrote:+1 on latch/bumper adjustments for Stephan: try some spray lube on the cables, sounds like one is sticking.
Stephan
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
I just fold up a business card and place it between the headlight and the hood before releasing the latch. The little upward pressure works every time. Used the key on the '98 in the same way, but the '99 key is a little fatter.
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
- Has thanked: 311 times
- Been thanked: 817 times
The root of the problem is shrinkage over time of the rubber bumper stopper pieces, one on each side, so there is not sufficient pressure on the hood to pop it up. Lots of solutions have been posted previously including buy new bumpers, install a shim under or over them, adjust the hood down. Good suggestions in this thread too.
