Was asked by someone on another forum what size aluminum washer he needed for his oil drain plug. He didn't have one and was going to look for one at AutoZone. Of course the best course of action is to order them when you get your oil filters at some place like fcpgroton.com but if you are ever in this predicament, here's is the size (I just measured, and it's easy to remember this!):
1. Diameter is exact size of a quarter (U.S. 25cents).
2. Hole in the middle is exact diameter size of a dime (U.S. 10cents).
(take a quarter & dime with you if you ever have to buy one at a parts store)
This crush washer size evidently applies to all FWD and AWD Volvo's (not sure about RWD Volvo's).
Remember that no matter what, NEVER USE A COPPER WASHER. It is too hard and will strip the threads on your aluminum oil pan.
Hope this information helps someone.
Just some info about the aluminum crush washer
- Has thanked: 17 times
- Been thanked: 35 times
White850Turbo
- Year and Model:
Wow, very cool. Definitely worthy of being put somewhere where everyone can see it.
-Sean
1998 S70 T5 (Almost Stock)
Thanks Sean,
I was thinking....if you take a quarter and a dime to an AutoZone, these two pieces of money will probably pay for a couple of these washers as well.
Happy Volvoing!
Happy Volvoing!
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 275 times
- Been thanked: 84 times
For all non-Americans (like me
25c
Diameter: 24.26 mm (0.955 in)
10c
Diameter: 17.91 mm (0.705 in)
(from Wikipedia)
25c
10c
(from Wikipedia)
850 T5-R '95 auto
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
After the second oil change on the 850 I went with a Fumoto brass valve with extended nipple. Happy customer. No problems with oil changes, no more hassel with crush washers, and no need for a oil plug wrench. It does drain at a slower rate so I do have time to pull the filter and perform my other service checks during the standard service. I have over 120K on the valve on the 850, 90K on the valve on the F150, 25K on the ES330, and 80K on the valve on the 944 with no leaks or any issues.
http://www.fumotovalve.com/
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
White850Turbo
- Year and Model:
Do you remember which model Fumoto valve you have?Tsquared wrote:After the second oil change on the 850 I went with a Fumoto brass valve with extended nipple. Happy customer. No problems with oil changes, no more hassel with crush washers, and no need for a oil plug wrench. It does drain at a slower rate so I do have time to pull the filter and perform my other service checks during the standard service. I have over 120K on the valve on the 850, 90K on the valve on the F150, 25K on the ES330, and 80K on the valve on the 944 with no leaks or any issues.
-Sean
- Tsquared
F-104 N The nipple is optional. Their website recomends an adapter but it is not required. It is a close fit. I used silicon pipe dope on the threads when I installed it.
'11 C30 T5
Sweet Wagon
- Year and Model:
I've always used a couple of layers of silicone tape on all of my cars, here and overseas, without any issues. I'll usually keep the existing washer and just have some silicone tape on the end of the bolt and the beginning of the washer.
I'm sure that some will have issues with that, but it's worked for me, and even my VW's stopped marking their territory after doing that.
That little F-104 N looks good though, I may have to switch to that...
For folks living in the San Francisco Bay Area:
I took my car in for a 60k service at Carlsen Volvo in Palo Alto. They managed to remove my fumoto valve and then charge me for a fresh OEM Volvo plug. I didn't even realize this until a few days later when I looked under the car and saw the shiny new plug looking back at me. I took the car back and they replaced my fumoto valve and refunded the $3.xx that they charged for the new plug. I had to wait over an hour while the mechanic went to retrieve the valve, I'm assuming from his home.
1998 V70
- akitawagon
- Year and Model: 1997 855R
That's interesting. Did they expect you to not notice the valve missing?
Did they give you any explanation for what they did?
1998 V70 T5 223K
1997 855R 215K
1997 855R 124K KIA... distracted driver on phone
1997 855 T5 141K KIA... water pump
1996 850 GLT 160K
1995 855 GTA 325K KIA... distracted driver on phone
1993 850 GLTS 201K KIA... t-boned
1997 855R 215K
1996 850 GLT 160K
- 15 Replies
- 8633 Views
Last post by volvolugnut
- 2830 Views
Last post by dm635
- 17 Replies
- 6255 Views
Last post by XC70Rider
- 642 Views
Last post by jonesg
- 36 Replies
- 24637 Views
Last post by StickyPocket
