Anyone know the actual fuel pressure of a 2.4 T? Can you of repair the pressure pipe? Mine was severed replacing the sway bar bushings, and before I go thru the trouble of replacing the line, I was wondering if the line can be repaired on the vehicle?
Thanks,
2002 XC70 Repair Pressure Pipe (Fuel line)
Rpappas
- Year and Model: 2002 XC70
Thank you vtl. Now I need to see if the hose can be repaired.
01 S60 T5 (victim of divorce)
04 S60 2.5T (victim of marriage)
02 V70 XC 2.4T
04 S60 2.4 (Totaled
01 V70 XC (donor vehicle for 02 V7 XC)
04 S60 2.4 (replacement for Totaled S)
02 V70 XC 2.4T
04 S60 2.4 (Totaled
- Been thanked: 4071 times
Probably much easier and cheaper to swage a piece of replacement line onto the damaged area than replacing the whole line, especially on an XC. You might have to buy a swage tool but you always wanted one anyway
Rpappas
Thanks abscate, I wound up cutting out the damaged piece, cutting the rubber outer housing away and using a fuel line repair kit I found at Pep Boys. I also wrapped the line in a heat shield to protect it from the engine heat, now that the rubber outer shell was removed. I apppreciate everyone's help on this, so far the XC is running great.
02 V70 XC 2.4T
04 S60 2.4 (Totaled
02 V70 XC 2.4T
04 S60 2.4 (Totaled
- 21 Replies
- 8071 Views
Last post by foggydogg
- 16393 Views
Last post by Richard99
- 83 Replies
- 50933 Views
Last post by 08XC90LOVE
- 5172 Views
Last post by darrylrobert
- 817 Views
Last post by 93Regina
