Hi
I have recently had intermittent rough idle with my volvo upon startup, sometimes even starting and then shutting down. There are no check engine lights.
Has anyone had this issue and would know the cause? It seems to be running fine now.
I decided to put some fuel injector cleaner in the tank (STP Super Concentrated 20oz). I was told that the best one to use however is Chevron...would it hurt to put an additional fuel system cleaner in the tank during the next fillup?
Thank you.
1996 850R Rough idle/Fuel Cleaner
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
It could be many things, but it's unlikely that fuel system cleaner will do much of anything. Have you thoroughly checked for vacuum leaks? How's the general state of tune with your 850? Miles? Any oil consumption?
'00 S70, '04 S60 and the never ending quest for Stage Zero
I have not checked for vacuum leaks. The spark plugs were changed 45,000 miles ago. Right now I have 196,000 miles on the car. The distributor/rotor and starter were all changed recently. I just had an oil change. Other then that, everything seems to be okay, getting about 20 miles to the gallon. I put in 89 octane fuel...maybe I should be using premium?
Aaron
Aaron
- RussB
I always ran/run super in my turbo's. 20 mpg is kinda low unless you're doing a lot of stop & go driving. I'm sure you're always running the AC down there!
- Has thanked: 311 times
- Been thanked: 817 times
I agree on the octane, I use premium (91 around here) in the turbo engines.
45,000 is a lot of miles for spark plugs, even if they are Volvo factory plugs, and these cars are pretty sensitive to ignition components. Pull a couple plugs and inspect them including checking the gap.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Tank or even fuel rail injector cleaners are a great idea.. for making money if you are in the market place. For anything else, I believe they are useless. A part restricted injector can cause poor idling and poor mpg and the only way to clean such injector is an ultrasonic injector bath which runs for about $15/injector on Ebay. However if they cause poor idling it won't go away by itself.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Spark plugs are a novice level job requiring minimal tools, time, and skills If you are so inclined, they also can give insight to the condition of your car. (PM sent) If your plugs are old, they may not fire efficiently, combined with hot wet Florida air and lower grade fuel, you are robbing the engine of its performance potential. Also, how old is your fuel filter, again, moisture in fuel can cause them to clog which will start by interrupting fuel flow, and will eventually cause your fuel pump to expire. (just like heart conditions!)
Plugs should be about a one hour job in a shop.
Current Volvos:
- 2233 Views
Last post by volvolugnut
- 2221 Views
- 719 Views
Last post by polskamafia mjl
- 2724 Views
Last post by DeadEric
- 17 Replies
- 1435 Views
Last post by vtl
