New fuel pump wont prime
I replaced my fuel pump in my 2000 v70xc awd tonight and tried to start the car and its like the pump isn't priming. It wont start, no fuel at fuel rail and the pump just sounds like its dry. Defiantly submerged, defiantly put in right.. What did i do wrong? Is there a priming procedure or should i have manually filled the pump or something? What are my options? Thanks!
- Has thanked: 1500 times
- Been thanked: 3812 times
Sometimes new parts are bad. Remove and apply 12 volts directly to confirm it is good
- Been thanked: 467 times
Is it:
- Brand-new Bosch pump?
- Used fuel pump from junk yard or ebay?
- Aftermarket fuel pump: what brand?
When asking for help, please include more detail, as detail is very important to help you trouble-shoot.
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
If you hand-wired an aftermarket pump, is it possible you've reversed the leads? I bet that would cause the pump to spin in reverse and cause your symptoms.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
