How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
hi im from italy and have a 850 t5r 95' euro model,it has a b5204 engine,i am planning to change the turbo but i need info.i contacted a dealer and he said that the TD04HL-16T-6 could go on easily,the only thing you have to do is or modify the downpipe ( ) or swap your used turbine housing and install with the new CHRA with compressor housing.Now the point is "which mod will cost less"? the downpipe o swapping......
What stock turbo does my car have?
If someone is so kind to explain to me what this dealer means about these dowpipes and swapping stuff.
