Some forums I've read say you can use a used one if you match the part number exactly- some say you can do this but will need programming and some say you can do this and it should be plug and play. SO, I found a used one online with a matching part number exactly, and put it in and it still does the same thing. I contacted the company prior to ordering to make sure it was a matching part, and they told me it would not need to be programmed.
My dilemma now is, does it need to be programmed? Or is it possibly my wiring? I'm willing to try anything aside from spend $1,200 on a stock radio on a car that I paid less than $5k for.
