98 S-70 GLT need to r\r waterpump & Timing belt
I need to change water pump & timing belt. Engine has a mech. tensioner. need info on how to release & retension. Engine is a B5254T. Should I r\r idler pulley & mech. tensioner and where should I look for parts as well as what identifing numbers do I need to be aware of ( ie. ser. numbers ). Do I need to jack engine up to thread new t-belt? Thanks.
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
You can snake it on without lifting engine. A little guard around the crank needs to be removed. Good write ups on here for the taking. I fought the belt on the bottom for a while, until I stretched it tight between both hands and somehow it slipped in between the crank and the metal tab easy. I would replace anything that moves it that area. More money now, saves time and money latter.
SHane
SHane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
my H20 pump started weeping. I contacted local shop & found the repair est. a little to expensive. I'm confident that I can make repair provided the weather holds. Ordered a tm kit & h20 kit should arrive soon. A little nervous about disturbing cam gears. Any tricks in locking them in place would be appreciated. Also, any advice in setting mech. tensioner,too. coolant leak has been going on for a little while, been keeping resv. up, temp gauge has stayed 1\2 way, hopefully no overheating damage. Veh. used for around town errands, not much hyway use or long hauls. Thanks.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Lil Red wrote:A little nervous about disturbing cam gears. Any tricks in locking them in place would be appreciated. .
Why? Just set timing to 0 before taking the belt off and make sure they are still 0 after putting the new belt on.
https://www.google.com/search?q=98+volv ... 00&bih=740
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
I followed the step by step narative and it worked out great. I did get one of those cam locking tool kits for about $100.00 and locked the cam gears from the back. The hydrolic tensioner is easy to reset with a clamp as shown in the narative. Cleaning off the old WP gasket takes time to get it correct. Doing this job seems scary until you do it for the first time. You may want to find a coach to take you through the job for the first time and to answer questions as you proceed through the job.
- RussB
- Year and Model: '00 S70, '04 S60
- Has thanked: 3 times
Lil Red,
I don't know how you missed it, but this posted at the top of this forum and contains all you ever need to know about changing your T-belt and water pump. You will need to jack up the right front and remove the tire
https://www.matthewsvolvosite.com/forums ... =1&t=47793
I bought my parts from FCP Euro.
Continental belt
Aisin water pump
INA tension and idler pulleys
Continental belt
Aisin water pump
'00 S70, '04 S60 and the never ending quest for Stage Zero
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Depends on the age of your motor mounts. Without sagging there should be enough clearance. On my last TB job I had to jack the engine up though to get it onto the crank shaft.Lil Red wrote: Do I need to jack engine up to thread new t-belt?
- RussB
polskamafia mjl wrote:Depends on the age of your motor mounts. Without sagging there should be enough clearance. On my last TB job I had to jack the engine up though to get it onto the crank shaft.Lil Red wrote: Do I need to jack engine up to thread new t-belt?
Good point!
If you need to jack the engine, you also need a new motor mount
obayha
Mark the gears and the notches in between the gears, with a grease pen. Make sure the new belt has the same notches between the gears and everything should be fine. I have done one one my old '98 and just did it on my '06 and everything worked right. Take your time, read twice, do once.
Shane
Shane
1998 V70 T5 331,000
- 34 Replies
- 5402 Views
Last post by regent
- 748 Views
Last post by cn90
- 1152 Views
Last post by chrism
- 4050 Views
Last post by shiloh51933
- 593 Views
Last post by jonesg
