Just bought a 2004 Volvo S60R AWD and it seems to run great with some small issues I need to address (later), but the big one that bothers me is that on half throttle it goes great, but on 3/4-full throttle it seems to hiccup or stutter. My thought was fuel delivery, but I dont know enough about these cars to know where to start.
Any idea?
Seems to have a few additions to the car that may effect it. K&N Ram air intake, straight piped exhaust (way too loud... Code for O2 Sensor is on).
Thanks in advance guys
2004 S60R AWD Stutters/Hiccups on Heavy Accel
JRL
- Year and Model: Several
- Been thanked: 16 times
Well, first replace the 02 sensor(s), then remove that K&N and check the MAF. If you think the 02 code is from the straight pipe then you need a rear 02 spacer
K&Ns wipe out MAF sensors with their oil.
Install a new set of OEM plugs gapped to .028 and go from there.
Why would would post this without at least replacing what you KNOW is bad
is beyond me!
Yeah I have heard about the K&N Filter oil issues, that being said it needs to be cleaned/re-oiled as well. Ill check the MAF in the process.JRL wrote:Well, first replace the 02 sensor(s), then remove that K&N and check the MAF. If you think the 02 code is from the straight pipe then you need a rear 02 spacer
Why would would post this without at least replacing what you KNOW is bad![]()
is beyond me!
Almost positive the O2 code is from the straight pip/lack of a CAT... feel like the old owner removed it.
Well I didn't know what was bad... Didn't know that an O2 sensor effects honestly... wasn't sure if that would effect it or if it was just a nonsense code. Thats why I asked lol. Thank you for the help with that. Would a O2 spacer fix the running issue or just get rid of the code?
1993 Volvo 850 (w/97' engine in it)
- 1279 Views
Last post by RickHaleParker
- 2242 Views
Last post by An R rated life
- 11 Replies
- 2242 Views
Last post by Sommerfeldt
- 640 Views
Last post by Cal01s80
- 24 Replies
- 6017 Views
Last post by joelobstahman
